Dental X Ray Machine suppliers
Fórum használata, saját profil, egyedi kép, hozzászólás sorrend, stb.
lili039
Csatlakozott: 2019. április 11., csütörtök 9:49
Hozzászólás Szerző: lili039 » 2019. április 11., csütörtök 9:56
Features :
1. This wireless dental x-ray is high frequency machine.
2. The body is small in size, light weight and nearly no radiation.
3. It has excellent image quality and portable storage, which will save more space.
4. High frequency and DC international power supply is used.
5. All components are installed in the central PC board concentrated. Shock, electron tubes, set-up, all of them are insulation vacuum and sealed stereotype protection.
6. There are also manual buttons installed on the shell surface, as well as charges and batteries.
7. This device is mainly suitable for oral pre-treatment for learning root depth, internal organizational structure and so on. It is indispensable clinic equipment in daily life, especially for dental implant surgery.
8. It can also be connected with sensor, which is great convenience.
9. The battery is large capacity. It can take about 5 hundred photos after fully charged.
10. It could be connected with the intra-oral digital x-ray imaging system to use.
Technical Parameter :
Tube voltage 60KV
Tube current 1mA
Exposure time 0.1--2.0s
Frequency 30KHz
Rate power 60VA
Distance from skin to cone 130mm
Tube focus 0.3mm*0.3mm
X-ray irradiation range 73mm (roundness)
Battery DC14.8V 6400mAh
Charger input voltage AC100V-240V±10%
Output voltage DC16.8V
Ambient temperature 5℃~40℃
Relative temperature <75%RH
Net weight 2.5KG
Gross weight 3.5KG
Size(mm) 138*165*185
Package :
1* Main unit
1* Charger
1* User manual Dental X Ray Machine suppliers
website:http://www.baistradental.com/dental-x-r ... y-machine/
